Name: DAN HOPPER |
hi guys hope your all well,
im working on a external image at the moment for the castle i showed before, i was wondering how do you guys create your grass, displacement, bump or texture? the camera will be getting quite low to the ground in some areas so textures might look a little suspect lol cheers dan |
Name: Alain Blanchette |
Well, for general grass, I would use displacement, (VRay user, so quite easy to set nice grass t) and in the areas where the camera is getting lower, I would use geometry, using "advanced painter", a free plugin you can find on the web, paints directly on any geometry:such as rocks, toothpaste, or, as you need it: grass
hope it helps |
Name: Stephen Leworthy |
99% of the time i'll use a textured/bump map. purely for speed. and done correctly you can get right down on top of it and it'll still look convincing. it's down to the quallity and type of base grass map you can find.
for still work i'd reccomend comping some real grass in over the top. if it's for anims, again, i'd first go with a basic texture map, but for real grass try the SPD shader. or plugins like Hair department (free) or StormTracer for example. Although all these will drastically slow down render times. |
Name: Dick Floris |
for grass i often use a photo of an emty field which i map on de object with a frontal mapping. You can look on www.sxc.hu for some nice grass photo's to use. Beware of the color and shadows on it. This might need some shopping.
good luch with your castle Sir Dan! |
| ******?? grass ??******** | solefishes | 3ds Max | 13 | May 3rd, 2005 02:35 PM |
| Flat mapped Grass Options? | MegaPixel | 3ds Max | 3 | April 2nd, 2005 05:47 PM |
| Freelancers wanted at Green Grass Studios in Dallas! | sandpiper | Job Board | 1 | February 3rd, 2005 08:07 AM |
| Procedure mapping for grass | Saturn | Autodesk VIZ | 2 | August 11th, 2004 03:48 AM |
| Rendering grass in 3D Max | Brian Cassil | Tips, Techniques and Frequently Asked Questions | 39 | August 2nd, 2003 10:33 AM |
