3ds Max Autodesk 3ds Max
Old July 25th, 2005   #1 (permalink)
Default creating mesh material
I need to create a metal mesh material that will be visable from fairly close (approx 10' away). I would like to be able to see through the mesh to what is behind it. I have created a bitmap with the mesh pattern on it, and applied it to the object in the diffuse slot. However, I can't seem to figure out how to see through it? Any ideas?
frank1331 is offline
Old July 25th, 2005   #2 (permalink)
United_States  Send a message via AIM to schmoron13 Send a message via Yahoo to schmoron13
Default Re: creating mesh material
apply it to the opacity map. Just remember: black=see through; white=opaque.
Doron Serban
schmoron13 is offline
Creating mountains "tutorial" edward80 2D/3D Tutorials 5 August 1st, 2005 08:11 AM
Chrome material problem evanmoses VRay Render 18 March 16th, 2005 09:12 AM
Terrain material plugin!? RSF 3ds Max 0 January 3rd, 2005 06:38 PM
Edit Mesh and Material Mapping Eric Autodesk VIZ 1 May 2nd, 2003 10:08 AM
