| Work in Progress (WIP) Post your works in progress here to get user feedback and critiques. |
Name: Dennis Munar |
Here's a 4 storey Residential Building which I designed, modelled in Max 7
and rendered with Vray 1.46. It's very first Vray exterior render any C & C's are welcome. Thanks!
"Theme, Colour, Concept,Proportion and Balance, and Function of Design" |
Name: Chuck Morgan |
i would:
create a direct light for the sun get rid of the noise get a better background image drop the pavement reflection give the windows some transparency and add some dirt to the pavement. displacement grass!!! vray can do it well... why are the trees blurry? what are your lighting settings? chuck |
Light Settings:
I used HDRI, 1 direct Light and 1 Vray dome skylight all shadows in Vray. Trees are RPC and Cars as well. Windows are simply mappings. Frankly i don't know yet how to create a dirt effect for the road. any suggestions?
You mean like using only a Direct Light as the light source, am I right?
and how about the verticals kindly be specific? is it on the structure or lighting? Thanks!
the vertical lines i think they are talking about is the perilax effect of your building as yoiu look up to it. this might work better on a taller building, but if you add the camera correction modifier to the camera (by selecting camera, right click, and add camera correction. ) it will keep the camera at 2-point perspective.
cars look a bit smashed. is it a super wide camera lense? |
Name: Larry Zasitko |
Get rid of the fisheye lens! to much curvature along the road and distortion. Try to keep walls vertical by having camera and viewpoint at the same elevation. I am not a fan of buildings that look like they are leaning backwards. Only time this works is with tall building.
Agree with the others on textures. Post again, be nice to see the cleaned up image. Larry |
| First Exterior in Vray, i need help | danteprojetos | Work in Progress (WIP) | 24 | July 26th, 2005 10:06 AM |
| vray exterior lighting trouble | frank1331 | VRay Render | 1 | June 24th, 2005 07:24 AM |
| VRay - House Exterior | TickerTocker | Finished Work | 6 | June 13th, 2005 08:53 AM |
| exterior glass in vray | ecastillor | VRay Render | 1 | January 31st, 2005 10:33 AM |
| Exterior perspecive - vray render | voltaire_ira | Work in Progress (WIP) | 5 | June 19th, 2004 03:47 PM |
