Re: Lighting Simulation research
lightscape is "more or LESS" integrated into max8 radiosity. you have nearly the same lighting analysis tools as in lightscape.
simply setup your scene with architectrual materials and let a radiosity calculation start. the most important fact are phyically based materials, it will work best when you use architectrual materials.
