Originally Posted by nisus
Have you experimented with depth falloff to save rendering time on not having to displace at larger distances?
Yes, at times I use various materials to control where displacement occurs on large objects. No sense in having a displacement calculation when it can't be seen (behind objects), or won't be noticable simply due to the camera distance.
Why do you set FG max and min radius to the same value? I've read that these should be 10x apart, basicly 1/10th and 1/100th of the scene diameters.
As I briefly mention in the tutorial, the settings I used are just for simple/fast preview renders. naturally, the FG won't be super accurate, but for testing, it works well. And since I really only needed a touch of skylight for this scene I just left the FG at my test values.
