Old July 27th, 2005   #1 (permalink)
carlangas's Avatar
Mexico
Default vray warning
hi all,
does anyone have any tips on spotting geometry (material) that causes warnings to appear in the vray message box? im getting a "material returned overbright....." and it gives me the geometry name but since I import most of my geometry from acad it all shows up as object "3dsolid". I know that it really is a material problem and not a geometry problem. is there an easier way to do this rather than start rendering without a material untill the culprit is found??? ohh,, all of my materials are vray mats.
thanks
Pleasure in the job puts perfection in the work.
carlangas is offline
Old July 27th, 2005   #2 (permalink)
Default Re: vray warning
I got the same issue when I started playing with vray - I assumed it was because I did not have vray materials. I would be interested in hearing any hints at resolving the problem. No that the wife is on vacation I will start learning that again next week.
mwhite is offline
Old July 27th, 2005   #3 (permalink)
check this help...
i guess it happens when you use the standard max materials with raytrace...
remove raytrace from the object and use vraymap for reflections.... if not reduce the glosiness of standard material....
sam
ksampath is offline
Old July 28th, 2005   #4 (permalink)
DennisHolland's Avatar
Name: Dennis de Priester
Netherlands  Send a message via Skype™ to DennisHolland
I've found out that the warning (just like the hdri warning and some other ones) is not very important. The 'material returned overbright' is nothing more than one of your rgb values (mostly the ultimate white point) is about to wash out a bit. Just turn your lights a little lower in strength or do nothing at all if it looks good.
__________________________________________
PRIESTERMEDIA
3D Visualisaties & Presentaties
Rotterdam, the Netherlands
DennisHolland is offline
Old July 28th, 2005   #5 (permalink)
carlangas's Avatar
Mexico
thanks all for your input...
yeah, I agree with that. actually my scene doesnt show any ovious signs of burnout and sometimes when rendering a different view I get no warnings at all. but its still kind of anoying to get those warnings
Ten vray questions steve VRay Render 10 September 13th, 2008 10:20 PM
Vray, Maxwell...................?? bully712 VRay Render 16 April 5th, 2005 08:36 AM
Vray and Brizal Rio plug in Chris Potts Other 3rd Party Renderers 7 September 16th, 2004 02:01 AM
about Vray versions and VIZ 4.2 salf VRay Render 8 March 2nd, 2004 03:47 AM
VRay against Vray and ... Sergio VRay Render 15 May 30th, 2003 09:09 AM
