Old February 5th, 2004   #1 (permalink)
Ras
Ras's Avatar
Denmark Send a message via ICQ to Ras
Hi
I´m just moving in to the wonderfull world of a dualscreen workplace. I´m not sporting the best setup (Radeon 9600) but the best I could afford.
Anyway - Whenever I start Autocad all the placements of the menus (on the secondary monitor) are reset to the primary screen (everything on top of eachother).
This is of course very frustrating as it takes time to redo it.
It seems that AutoCad (Architectural desktop 2004) isn´t setup right?!? I´ve looked at the screenmode system vaiable and a lot of other places but I can´t seem to find it.
Im sure its very simple - can anyone give me a tip?
Regards
Ras
Ras is offline
Old February 5th, 2004   #2 (permalink)
France Send a message via ICQ to NEVIANS Cedric Architect Send a message via Yahoo to NEVIANS Cedric Architect
hello
actually lot of Autodesk product don't use dualscreen mode...
actually use Revit 5.1 and it don't use dualscreen orangeno
so .. the 6.0 US version not anyway ...
demand autodesk for 6.1 ...
wait and see..
but some infos i've got from my autodesk resseller
say .. ADT not in dualscreen..
very dommage for professionnal software!!! :ngesighw:
NEVIANS Cédric -=- FRENCH ARCHITECT D.P.L.G
Wood and Iron construct Specialist
and CG Architectural render
Autodesk ATC teacher (Viz)
Amapi Pro 7 and Revit user.
http://www.zonetectural.net
and expo at eOVIA user gallery
NEVIANS Cedric Architect is offline
Old February 5th, 2004   #3 (permalink)
Ras
Ras's Avatar
Hi Nevians
Thank you forr your reply. Its nice to know I´m not alone. But tell me - how do you work aorund this problem?
Also - Screenmode does mention a dual screen setup but nothing about how
There must be some way to do this without having to move the toolbars al the time.
Regards
Ras
Ras is offline
Old February 5th, 2004   #4 (permalink)
I don't know if this will work, but we use AutoCAD LT w/ Duel's and it works. Duel 21" on Matrox 650.
Try going to display properties and highlight the second moniter. Check "Extend my Windows destop onto this moniter". See if that does it.
Chaz
Chaz is offline
Old February 5th, 2004   #5 (permalink)
Angry
hello bis,
so .. warning...
there is 2 mode in dual screen :
the "real" DualScreen ...
that 2 screens = 2 desktops = 2 resolutions pixel
(exemple : 1600x1200 and 1024x768 for second..)
and the "false" dualscreen :
that windows only extend primary screen int o the second
you have only one screen (mega screen but one only)
(example : 2600x1200 and the resolution pixel is blocked.. you can't change the second screen..
so you must use same monitor and the same resolution on the two monitors..)
so alls softs run on False Screen mode..
but not lot of on real dualscreen ...
Actually Autodesk product (autocad)
can run in false.. and sometimes in real mode..
(test it !!!)
but ADT and Revit don't run for moment i think (i'm sure for revit not for ADT ..)
good day
edition PS : yes the problem that lot of software don't save windows position....!!!
Adobe product YES .. other .. no be ...
Old February 5th, 2004   #6 (permalink)
Ras
Ras's Avatar
Hi guys
Ok - well I can set the resolution independently for both monitors - so I gues its "true" dual.
I have "extend my windows..." on and it works. The problem is that Autocad does´t remember my settings when I close the aplication and open it again all the toolbars are moved to the primary monitor - on top of eachother.... very irritating.
Any ideas?
Regards
Ras
Ras is offline
Old February 5th, 2004   #7 (permalink)
President/Founder
Jeff Mottle's Avatar
Interesting. I've never tried that with ACAD, but I can not get it to work either. I thought it may work with me becuase I use UltraMon ( http://www.ultramon.com ), but no dice.
Jeff Mottle
CGarchitect.com
Jeff Mottle is offline
Old February 5th, 2004   #8 (permalink)
I think your out of luck with acad on duals
Nvidia has a method of saving settings for different programmes....not tried it though
siliconbauhaus is offline
Old February 6th, 2004   #9 (permalink)
3dp
Name: david pinnington
Bahrain
not being helpful but those old enough dos autocad will rmember the two screen setup with command line running on a 14" at the side
at one time i was quite good on cmd line acad
kinda miss it now
can i have everything louder than everything else please
3dp is offline
Old February 6th, 2004   #10 (permalink)
David Knourek's Avatar
Like siliconbauhaus said Nvidia drivers have an option to set prefs for different apps. Have a look through your display drivers and see if there are any options to do that with your Radeon.
-dave
I reject your reality and substitute my own
David Knourek is offline
