Go Back   CGarchitect.com > 3D SOFTWARE > Maya
Maya Alias
Old August 24th, 2005   #1 (permalink)
Name: Andrew Bloomfield
Default how to model a geodesic sphere?
any ideas how to model this??? http://www.solarius.com/assets/galle...t_se_2001a.jpg
thanks!
nitroblaster is offline
Old August 24th, 2005   #2 (permalink)
a_w
Default Re: how to model a geodesic sphere?
This may not be the quickest way, but as a start, you'll want to get the dnPolyhedron MEL script from: http://dannyngan.com/tools.htm
That will net you your base shape, an icosahedron. Once you have the icosahedron:
1. Switch to Vertex component level and select all the vertices on the icosahedron.
2. Edit Polygons menu > Poke Faces
- each face should get a new vertex at its center.
3. Edit menu > Invert Selection
- now you should have the vertices at the center of each triangle selected.
4. Uniformally scale the vertices to push them out from the triangle's center.
5. Edit Polygons menu > Normals > Soften/Harden for a faceted look.
Good Luck,
a_w
a_w is offline
Old August 24th, 2005   #3 (permalink)
thanks so much! I downloaded the script but how do install and use it? im really sorry ive never used script in maya
Old August 25th, 2005   #4 (permalink)
a_w
1. Unzip the dnPolyhedron.zip file you downloaded from Danny Ngan's site.
2. Copy the dnPolyhedron.mel file into Maya's scripts folder. You can typically find this folder (if you're using Windows) at the following location:
My Documents\maya\6.0\scripts -or- My Documents\maya\scripts
(if on OSX) ~/Library/Preferences/AliasWavefront/maya/scripts/
3. OPTIONAL SHELF ICON
Copy the accompanying two .bmp files into Maya's icons folder:
My Documents\maya\6.0\prefs\icons
Start Maya, then type dnPolyhedron in the command line and hit Enter. You should get the dnPolyhedron menu, where you can customize your icosahedron. Maya is case-sensitive, so make sure you capitalize the P, otherwise you'll get a "Cannot find procedure" error.
a_w is offline
Anyone else model in AutoCAD? Anyone use file linking? Reitveld AutoCAD/AutoCAD Architecture 44 September 27th, 2008 05:59 PM
Help! Model Problems. swenson 3ds Max 0 February 23rd, 2005 09:17 PM
Help! Exporting workable hidden-line drawings to AutoCAD from a 3Ds model? brinkadelic 3ds Max 3 December 5th, 2004 04:41 PM
Need a model of a simple contemporary home tachyon99 Job Board 1 July 17th, 2004 12:03 PM
Organizing the model. Hector Lightwave 5 April 10th, 2003 12:33 AM
