Old November 28th, 2005   #1 (permalink)
myriadz's Avatar
Singapore
Default Skydome
Hi
I'm just wondering,
I've never used the skydome thing in Lightscape. How does one go about doing that?
After applying the HDRI image onto one, do you assign the entire dome as a WINDOW/OPENING?
if i model this dome in MAX/AUtocad, wont there be a million vertices which would slow down the processing time etc?
Would like to experiment with it, can anyone give advice? or a quick tutorial?
Thanks a million!!
myriadz is offline
Old November 29th, 2005   #2 (permalink)
Default Re: Skydome
are you shure that LS support HDRI?
okmijun is offline
Old November 29th, 2005   #3 (permalink)
Switzerland Send a message via ICQ to rpict
Default Re: Skydome
hi, i've done that in the past for interior/exterior scenes, to catch both in one shot. make a rough hemisphere over the entire scene (geosphere, octa, 3-4 segments, hemisphere). face the normals inwards and define it as opening. then process it as interior and let it run till 98%-99%. reduce the brightness to 10-20 to compensate for the strong skylight in the exterior part. to get an nice and smooth solution, it also needs a fine mesh resolution for the interior parts and a clean modelling.
-rpict
rpict is offline
Old December 7th, 2005   #4 (permalink)
Default Re: Skydome
I would suggest a different thing:
Place a hemisphere with fine mesh in the scene and a lightsource in the middle of this hemisphere. Then let lightscape do one iteration and stop the process - When you have enabled textures the mesh stores the light and would bounce it back to the scene with the next iteration - now go and merge this skydome to a different scene and let there bounce the light/color information back to scene.
[see.]
seismograph is offline
Old March 7th, 2008   #5 (permalink)
Default Re: Skydome
Can some clearify this trick, please.
Wich would be the best way to handle exteriors.
Im starting to use LS on exteriors, and Im very, very far from the interior results:-(
Beeeee!
del82 is offline
Old March 7th, 2008   #6 (permalink)
Sweden
Default Re: Skydome
Thanks for the tip
Iam always used it as an opening for the skylight. Could only use it to get nice reflections.....
Gonna test your tip.....
Cheers
Johan Sae-Thao
djmj is offline
Old March 7th, 2008   #7 (permalink)
Default Re: Skydome
...whats the light source thats placed in the middle of the hemisphere?
You mean like defining one poly on the hemisphere like an opening?
Beeeee!
del82 is offline
Old March 8th, 2008   #8 (permalink)
Sweden
Default Re: Skydome
I tried to merge the solution file of the skysphere into another ls file. Crashing everytime
I just saved my scene file as ls file, didnt start any radiosity calculation what so ever, merged my skysphere ls file, where I stopped the radiosity calculation just after one iteration like you said, pushing the run button. Crashing everytime.....
Hmm
Dont know whats going on....
Cheers
djmj is offline
Treeline - Skydome Lighting MegaPixel 3ds Max 5 May 20th, 2005 07:49 AM
premade Lightscape skydome? jayadams Lightscape 1 March 30th, 2005 02:27 AM
hdri skydome tutorial ...update. seismograph 2D/3D Tutorials 3 September 15th, 2004 01:41 AM
Exclusion from alpha channel nisus Tips, Techniques and Frequently Asked Questions 4 August 30th, 2002 02:35 AM
