Re: Memory usage
YUP! You can read all you want the way you want it. The nature of progresive refinement as implemented in LVS is not multi-threaded. You can wish but it wont happen. Generation of 'image' means rendering 'frames' and yes LSNET will help there but solution processing NO!!!!!
How many times will I have to explain this one again and again? There is a big difference between 'rendering' an image vs 'solution processing'. FYI I talked to the people who made Lightscape along time ago privately about these matters and sadly LSnet wont work with solution processing.
_ _ ______________ _ _
Arnold Gallardo
Visual Content Creator
Technical Writer
and Techniques'
