Old January 4th, 2006   #1 (permalink)
Maxer's Avatar
Default AMD problem
My company just purchased 7 new AMD Athlon Dual Core 64 bit 4400+ machines and I've been doing some comparison tests against an Intel 3.6 GHz Pentium. So far the AMD is 37% slower than the Intel, but I'm not sure if everything is working right. I have a dual processor dual core AMD Opteron system and the task manager shows 4 processors, these Athlon systems only show one processor in the task manager, but I think they should be showing two. Can anyone help me here, I don't know if these processors are functioning correctly.
Maxer is offline
Old January 4th, 2006   #2 (permalink)
AJLynn's Avatar
Default Re: AMD problem
It should show two processors. Sounds like your vendor screwed up - this should work without modifications, but did you check the bios and check with your vendor and MB manufacturer to see if there are any bios upgrades you need for the dual?
AJLynn is offline
Old January 4th, 2006   #3 (permalink)
Maxer's Avatar
I'll check....I thought something was screwy.
Maxer is offline
Old January 4th, 2006   #4 (permalink)
what motherboard, did you get, the last system I installed, I had to update the bios and now it shows 2 cpu's. some of the motherboard manufacturers, now are able to let you update the bios thru windows now which is really nice, then all you do is reboot and your good to go.
Mike
mtutaj is offline
Old January 4th, 2006   #5 (permalink)
Maxer's Avatar
It turns out it was a BIOS problem, the boards shipped with a 2.xx version and when we updated they were at 19.xx, so I guess they've been sitting in a warehouse for quite some time.
Maxer is offline
Old January 4th, 2006   #6 (permalink)
AJLynn's Avatar
Cool. Now can you show us some examples of what you can do with 7 dualcores?
AJLynn is offline
Old January 4th, 2006   #7 (permalink)
Maxer's Avatar
Yes Sir!
Maxer is offline
Old January 6th, 2006   #8 (permalink)
CVC
CVC's Avatar
Name: Cao Viet Cuong
Viet Nam Send a message via ICQ to CVC Send a message via MSN to CVC Send a message via Yahoo to CVC
go go go Maxer , can u show some cpu test ????
what's ur mainboard ???
Best Regards,
-Cao Viet Cuong-
E5 design&construction.,JSC
Website: http://www.e5-jsc.vn
CGportfolio: http://cvc.cgsociety.org
CVC is offline
Old January 7th, 2006   #9 (permalink)
United_States  Send a message via Skype™ to DennisB
Now what kind of performance are you getting relative to Intel?
DennisB is offline
Old January 7th, 2006   #10 (permalink)
Maxer's Avatar
The AMD system is a little more than 40% faster than the Intel 3.6 GHz 64 bit system. The AMD system is also $300 less than the Intel system, so as of right now unless Intel changes something either in their pricing or speed of their chips we will be buying all AMD systems.
Maxer is offline
HELP: AMD X2 + Max7.5 problem visions Hardware and Technical Discusions 5 December 13th, 2005 04:31 AM
AMD Dual Core Issues? JamesTaylor General Discussions 9 December 5th, 2005 07:19 AM
amd 3200, 939 help haneet khanna Hardware and Technical Discusions 1 June 12th, 2005 05:35 AM
Nikon Capture Editor And Amd Elliot Digital Photography 3 January 17th, 2005 11:09 PM
