Name: Raymond Salmon |
is there any way to save an image in PS with the grid showing in saved image. the grid itself is a helpfull part of an image...
now i am just overlaying a opacity map which is a grid... but it would be easier if all the fine tuning could be just done with the grid feature... i lost so much wieght my wedding band fell off.... |
Name: travis schmiesing |
you could turn on snap to grid, make a path with the pen tool by snapping to the grid lines you want, then stroke the path with the desired pen thickness you want.
i do this often when i am making flooring tiles.
travis schmiesing |
Name: Chad Warner |
You could make a pattern that is the size of one grid square (make a square selection, stroke the selection, then go to the edit menu and "define pattern" and then fill a layer with the pattern you made (edit menu, fill, use pattern, then custom pattern, choose the pattern you just made) Voila..instant grid.
| Image size and resolution | blair | Photoshop | 4 | May 24th, 2007 09:06 AM |
| Rendering Problems/ huge image | dnagi | General Discussions | 6 | February 8th, 2007 03:33 PM |
| Further analysis of jpeg image compression... | crazy homeless guy | General Discussions | 3 | March 20th, 2005 12:21 AM |
| how. ? | anvaraziz | General Discussions | 9 | December 4th, 2004 11:35 AM |
| Newbie Question: Is this image difficult to create? | JAVB | Autodesk VIZ | 3 | November 16th, 2003 02:01 AM |
