Old January 17th, 2006   #1 (permalink)
Name: Jose Alberto Gonzalez Ornelas
Mexico
Default Arch Window
Hi there I have a very big problem with arch windows, the thing is that i create a poly line closed by an arch, then extrude it, extrude the line thats supposed to be the wall and then substract the "arch window" hole from the "wall", when i link the file into Viz 2005 the archwindow instead of being an arch with many segments, smooth and "circular", becomes an arch of three points, how can i improve this.
Jago_0108 is offline
Old January 18th, 2006   #2 (permalink)
Saturn's Avatar
Default Re: Arch Window
If you are using File Linking, there is a way around this. After linking the model go back to the file link menu and click files. Then hit reload and you will get a dialog box. On the bottom right there is something about surface deviation or something like that. Change it to .1". This should smooth out the surfaces.
Jason Matthews
Saturn is offline
Old January 18th, 2006   #3 (permalink)
Name: Kyriakos Kyriakopoulos
Greece
You can also raise the number of curves.
Look the tuts that came with the program.
There is a section about cad links and how to bypass some other problems too.
makemono is offline
Old January 18th, 2006   #4 (permalink)
Mexico
Thanks for your help I tried both advices but could not get the results I wanted here is an image of the problem I mean, could it be the type of arch I'm doing in Acad? If so, what kind of arch should I do to get more points in the curve? Thanks for your help.
The red one is the one linked with the file link manager from acad.
The other is a window i tried to fit in it but the number of points in the arch did not coincide
Old January 18th, 2006   #5 (permalink)
ecastillor's Avatar
Mexico
This always works for me...
ecastillor is offline
Old January 20th, 2006   #6 (permalink)
Saturn's Avatar
Yup. Thats the one. The lower the better, but do not set it to 0.
Jason Matthews
Saturn is offline
Arch. Desktop: double hung window in a curved wall?! Aspiring Visualizer! AutoCAD/AutoCAD Architecture 2 May 1st, 2008 06:18 PM
window glass problem roland Work in Progress (WIP) 5 January 2nd, 2006 03:00 AM
ARCHEVER - world's finest arch visualizations PanzerG General Discussions 10 November 9th, 2004 03:38 AM
window animation, noob help Pumuckle General Discussions 2 July 1st, 2004 05:17 PM
Reflection in glass window magnifying lmorales Lightscape 1 October 8th, 2003 01:28 AM
