| Archicad Archicad |
Name: Troy Williams |
I am having problems assigning matrials in max to my model imported from archicad . The biggest issue is the generic naming of the objects when imported.
Does anyone have a decent process they use or will I have to rename each of the 100's of objects in my scene. Ive also tried to obtain material from object and just change the material properties but this doesnt seem to update all the objects with the same material names attached to them |
Name: martin prochazka |
change export setting in archicad /select objects by material in max is sometime usefull too/
http://martinprochazka.cgsociety.org |
ok after searching around i came across this tutorial http://www2.ds.arch.tue.nl/tiki/tiki...ter%20Tutorial
i downloaded the plugin and the material replacer works great. Thanks martincg im sure the select object by material idea will be usefull as well |
| ArchiCad to Discreet 3ds Max 7.0 | brqlumpkin | Hardware and Technical Discusions | 1 | September 19th, 2005 09:50 AM |
| strata studio to max | esilvis | 3ds Max | 0 | June 24th, 2005 08:57 AM |
| CAD to MAX issue......snaps problem | salf | 3ds Max | 6 | June 9th, 2005 12:43 PM |
| Archicad and 3D studio | Maxer | Archicad | 3 | October 13th, 2004 09:08 AM |
| Very impressed with 3D studio max | philip kelly | 3ds Max | 5 | August 27th, 2004 07:38 AM |
