Old January 31st, 2006   #1 (permalink)
RAYMOND's Avatar
Default viz 2005 will not load... need help soon
my viz2005 loads then displays "will have to close" then just shuts down..
i have removed the program from the drive and reloaded from the disk... but strangly the old UI comes up with custom tools etc ... how can this be?? i believe the problem is in a script tool at least that is were the problem began... but how do i reload a max file with the defaut UI... i can't remove the tool since the program shuts down..
I have Viz4 but it doesn't seem to want link in AD2005 dwgs...
RAYMOND is offline
Old January 31st, 2006   #2 (permalink)
RAYMOND's Avatar
Default Re: viz 2005 will not load... need help soon
looks like i fixed it.
just deleted a mcr file which had a bad call in it...
kinda a tough bug to find tho......
RAYMOND is offline
announcing papercrete summer 2005 papercrete General Discussions 0 April 24th, 2005 06:45 PM
Confused Viz 2005 Elliot Autodesk VIZ 2 October 3rd, 2004 01:16 PM
VIZ 2005 upgrade trhoads Autodesk VIZ 3 September 16th, 2004 10:00 AM
VIZ 2005, does it have light tracer? chuck Autodesk VIZ 6 May 19th, 2004 05:36 AM
