| finalRender cebas finalRender |
Name: Ahmad Jadallah |
Hi,
I am using MAX 7.5 SP1 and Final Render Stage-1 SP2D and I am having problems with RPCs. I attached a screenshot, as you can see , the rpc is in the scene is suppose to walk toward the bottom left corner and it works with scanline renderer. However, when rendering using Final Render two things happens: 1- the rpc is facing the opposite direction and it starts on the opposite side of the spine (meaning its facing the top right corner) 2- The RPC does not move at all. Not in position and not in frame-by-frame animation. It just stays still in an animation. Note: I tried this with different RPC contents and on different machines. when I add a reguar RPC "say casual people talking in place" the final render animation doesnt move at all. It just shows one frame during the whole animation. |
Where do I get the RPC plugin update for Max 7.5
I couldnt find it on their website (www.archvision.com) and besides, RPC works ok with 7.5 scanline. Its just when I use final Render it gives problems. |
Name: Alex Vasiliuk |
yes, i had the same problem, you need RpcAutodeskDiscreet plug-in, here it is, with it animated rpc works fine with Final Render...here is the link
http://www.archimaging.com.au/rpc/plugins/index.htm |
