Old February 2nd, 2006   #1 (permalink)
Default rendering a scene with reflective materials are killing me
how can I reduce the rendering time when I have reflective materials?
d7man2000 is offline
Old February 2nd, 2006   #2 (permalink)
diegofer_9's Avatar
Default Re: rendering a scene with reflective materials are killing me
If you are using VRay, you can turn off reflections in the Global Switches Tab. If you are using Scanline, I dont know if there is a way.
diegofer_9 is offline
Old February 2nd, 2006   #3 (permalink)
Argentina
A wise use of User Interpolation can decreate your render times A LOT without a major visual impact. Play a bit with the values...
MandelbrotJr is offline
Old February 2nd, 2006   #4 (permalink)
ecastillor's Avatar
Mexico
reflections are usually a breeze for vray...except for blurry refs...check your glossines value....1 is no blur....ans the less you go is more blury...if thats the case, try reducing the subdivs in your material
ecastillor is offline
Old February 2nd, 2006   #5 (permalink)
alfienoakes's Avatar
Eduardo is on the money with blurry ref's ..
Take the sub divs right down to about 5, think the default is 50.
Then work upwards from there..
Andy
Andy Wiggins
MAKING COFFEE.
Making a cup of coffee is like making love to a beautiful woman. It's got to be hot. You've got to take your time. You've got to stir... gently and firmly. You've got to grind your beans until they squeak. And then you put in the milk.
Swiss Tony.
alfienoakes is offline
Old February 2nd, 2006   #6 (permalink)
i reduced everything to minimum, subdivision to 1, max rate to 0,
it is still same thing, I want to create a flyby animation of the building and I have a rendering farm at work but still 1 frame takes too long with all this reflection. I did it with Mental Ray and it was quick. Now I do same thing with Vray and it is taking forever, I can't imagine how long it would take with only one processor computer.
I think interpolation would be the only solution
MandelbrotJr,
Can you tell me what setting you would have ?
thanks guys.
Old February 2nd, 2006   #7 (permalink)
Sawyer's Avatar
You may need to post a more detailed example like scene settings, material settings. Keeping the material subs at 8 and refl glossiness at 1 should be pretty quick. What are the render times that you have now?
Sawyer is offline
Old February 2nd, 2006   #8 (permalink)
about 25 minutes
Old February 2nd, 2006   #9 (permalink)
Argentina
I agree with Sawyer, if you are using refl glossiness at 1 VRay should render the frame really really fast as it just raytracing.
What are this relective surfaces actually reflecting ?
Old February 2nd, 2006   #10 (permalink)
Sawyer's Avatar
Post what you have and we will look at it.
Sawyer is offline
Searching scene materials dbarc 3ds Max 7 November 3rd, 2005 05:38 AM
Rendering a photo within my scene problem jamiebyers 3ds Max 3 March 29th, 2005 06:48 PM
Rendering a scene with video post Jordy 3ds Max 2 December 2nd, 2004 07:11 PM
Help! Materials For Rendering Al_Zyma General Discussions 4 August 20th, 2004 05:57 PM
