Old February 7th, 2006   #1 (permalink)
Question Boolean Problems
i tried making a wall with two windows, one square and one with an arched top... for the one with the arched top i 'connected' a rectangle and a sliced cylinder. when i try to make a boolean obj using this object, a rectangular cut is only seen...the cylinder part of the window is completely ignoreed, how do i make it be really part of the object i am trying to use??
claudia777 is offline
Old February 7th, 2006   #2 (permalink)
Name: Karl Zacharias
Default Re: Boolean Problems
a tip for booleans I learned here is to attach all the boolean objects into one editable poly...and boolean all at the same time...with your arched window I would make the boolean object from a line and extrude the profile, turning it into a poly and attaching the box boolean as an element...making one object...booleans are someties unpredictable...try using poly walls on a subobject level to create openings.
karl zacharias is offline
Viz 4 Crashing problems Showcard Autodesk VIZ 4 February 15th, 2007 02:20 PM
Exchange3D.com Problems bully712 General Discussions 4 February 13th, 2007 05:18 PM
MR Opacity problems and billboarding Brett Other 3rd Party Renderers 2 March 24th, 2005 12:09 PM
Memory Problems: 2GB limit ??? nisus General Discussions 2 November 9th, 2004 09:51 AM
Boolean Problems Sergio 3ds Max 12 November 23rd, 2003 06:04 AM
