3ds Max Autodesk 3ds Max
Old February 8th, 2006   #1 (permalink)
South Africa
Angry Snap and Pan problems
Hi all,
I do visualization for some time now. I was thinking how could make process quicker. What I usually do is inport cad drawing freeze and trace. Maybe it is not the best way, but in any case, during that I got some problems.
For tracing i usualy use line tool. in that proces i usualy get some problems:
1. while using line tool, I miss intersection snap (from cad) in max.
2. during the redrawing, i zoom quite much, draw than zoom out to draw again. If i try to pan (with a middle button) line "jumps" out and stops, if you know what i meen, and then i got two options to start again, or make another line, attach, and weld. Is there a method for paning while drawing the lines in max. In cad that is quite "normal" you are drawing line, pan and than continuing with a next node...
Best regards
Sergio
We make a living by what we get, but we make a life by what we give!
Sergio is offline
Old February 8th, 2006   #2 (permalink)
archkre's Avatar
Argentina
Default Re: Snap and Pan problems
To interactively Pan & Zoom in Max we have some keystrokes, which I don't remember now!([ and]for Pan or something like that!)
Go to the list of keystrokes in your Max and you'll find them out!
'Back in the young fatherland'
archkre is offline
Old February 8th, 2006   #3 (permalink)
Rick Eloy's Avatar
Go to Customize -> Preferences -> Viewport and turn Zoom About Mouse Point on. That will make your mouse scroll work like a point zoom, ie, your zoom will focus the mouse pointer. Since scrolling does not interfere with the line command, you can zoom in and out, even emulating pan with just a sroll.
Rick Eloy
Rick Eloy is offline
Old February 8th, 2006   #4 (permalink)
South Africa
Post Re: Snap and Pan problems
Thanks archkre!
Thanks Rick!
I already did those changes in customise a long time ago, and zooming in and out, but is so slow. If I rotate wheel on mouse it zooms in and out no problem, but if I press and move whole mouse (in order to pan) just stopes the line command. I suppose you can not compare to the cad, where that function is working ideally. Any other ideas, please.
Sergio is offline
Old February 9th, 2006   #5 (permalink)
Rick Eloy's Avatar
You find that slow? I don't know, once you get the grips with it it's just as fast as the real pan...
Rick Eloy
Old February 9th, 2006   #6 (permalink)
South Africa
Wink Re: Snap and Pan problems
Rick, I think you are right, I just want to impruve my overall speed and quality lately, and maybe you can not save much time by doing this. As they say, don't use the force, pick a bigger hammer, LOL.
Sergio is offline
