A quick question with the new Sky object in 9.5.
I want to create a physically correct animation of the sun and moon etc as we all rotate about the sun to show clients how passive solar design can help in Architecture. My problem is, if I apply a light as the sun in the sky object, it's intensity varies as if C4D is adjusting to the time of day on earth (which is fine for an earth view but I want a satellite view).This means I need the sky to basically remain as stars and a lightsource for the sun (appears) to rotate about the earth object. Is there a way to overide this setting as I want to show the difference between the Northern and Southern Hemispheres. Cheers
Wokka C4D R10.5 - VRayforC4D 1.087 ArchiCad R11 |
I'm not able to get the full question in my brain. It must be full.
But you should be able to animate day/month... Also, you can use a different light as a 'sun' though SKY will vary its output color even if you don;t want it to. Even though you described your task well, can you fill in more of how you see this working? |
Basically I'll be showing an near earth orbit animation over several points on earth with a few large 'structures' to represent a buildings. I'd like to show (say) the sun angle during Febuary down here in the South then swing up to the Northern Hemisphere to show how you crazy guys up North have Winter at this time of year (weird).
I have tried using a different light in the sky object but as night falls in the South the light automatically reduces to zero intensity. Maybe I'm missing something here? I suppose all I really need is a sun (object-light) to move in correct reference to an earth object. Sorry if I'm not being clear.
#4 (permalink) | |
Name: Jorge Arango |
Hope this helps. Jorge Arango |
