The biggest problem I've had with this test was keeping the host app, and especially the DR slaves alive. There were many, many crashes of one or all. Getting this test rendered required much babysitting of the computers and more time than I had planned.
This is not a final treatment, and I would be filtering the results a lot. I have some NPR treatments in here, more in Photoshop later. I'm not sure all the things that normally work in AR2.5 are coming out the way I expected, so I have to study this result and maybe adjust my scene. The frames ranged from about 2 minutes to 10 minutes (prepass + render) depending on how much glass was in the frame. http://www.architecturalvisions.com/temp/Webs-01.mpg |
Ernest
I must say, there is something quite distracting about the animation. I think it is the grunge layer, that is still over the top, of the animation. There is heavy flickering and bad antialiasing on the main elevation of the building, is this just because of the compression? When you get close in it is easier to se the building and the quality of the render comes out, There also seems to be some transparency, alpha map problems on the trees, something like the ray depth/ transparency depth in AR. I know this is just a test, cant wait to see the development. Lee
www.buzzbox.eu |
#3 (permalink) | |||
Thanks for the comments! |
#6 (permalink) | |
I usually do not use AA because of the time hit. My finals are processed to add noise and that helps. I have to look into how to introduce some AA, but to test the GI it wasn't necessary. The sky is just a gradient, by the way. Another thing I was playing with here. But its the GI, which worked well, that was the real test. I am completely satisfied with how it performed, just not the program itself. Here's a filtered version: http://www.architecturalvisions.com/...bSci-WC-01.mpg |
#7 (permalink) | |
Yeah, this is a bug.
In Cinema you have noise, and one of its parameters is 'animation speed'. Set to higher than 0 and the noise will 'dance' randomly. That's what I want it to do. In fr2 it isn't. Here's fr2: http://www.architecturalvisions.com/...-dif30fps-.mov Here's AR2.5: http://www.architecturalvisions.com/...-dif30fps-.mov As you can see in my scene test, when the background noise just sits there it looks awful. So to use fr2 I would have to workaround this bug which can be done by rendering without that noise on and adding it in After Effects. But another reason that fr2 isn't doing what I need...I didn't need. And here's what 10fps noise looks like, this is what I was after: http://www.architecturalvisions.com/...-dif10fps-.mov Last edited by Ernest Burden; February 27th, 2006 at 02:58 PM. |
Ernest
The thing I like about your work, apart from the lighting, and texturing..... oh and the proportioning of the images is the line quality you get on your stills, nice rich lines, it works with your style really well. And I think that is missing from the animations, there is not the same definition of line and light, I imaging that you do a lot in post, Photoshop blends and filters, or is it all in the render? I have had a little play during my lunch and what do you think of this? http://www.leedavid.co.uk/movies/0Comp1.divx hope that works.... save file to desktop and get rid of the.tex.... 380kbs you may need the VLC media player to view. http://getfreedownloadz.com/index.as...a4519a0&sft=34 All done in post though AE, I think you have got much more control with the multi layer approach. Lee
www.buzzbox.eu |
| Animation Help | steven martin | General Discussions | 0 | July 15th, 2005 01:51 AM |
| executive wing animation | crazy homeless guy | Work in Progress (WIP) | 30 | June 21st, 2004 03:20 PM |
| test test test | Jeff Mottle | Test Posts | 6 | March 16th, 2004 05:26 PM |
| Animation test | STRAT | Work in Progress (WIP) | 12 | March 1st, 2003 04:48 AM |
| Animation test no. 2 | STRAT | Work in Progress (WIP) | 5 | March 1st, 2003 04:29 AM |
