Autodesk VIZ Autodesk VIZ
Old February 27th, 2006   #1 (permalink)
Default file linking curved solids into viz from acad
When file linking dwg objects with curves such as cylinders and curved walls etc. i get segmented solids rather than smooth curves. I have my Acad settings and Viz Filelink settings as shown in attachment.
Please advice.
thks
fernando-1 is offline
Old February 27th, 2006   #2 (permalink)
Ray
Ray's Avatar
Default Re: file linking curved solids into viz from acad
Curve Steps to 100.
Surface deviation for 3D solids to 0.013.
Ray is offline
Old May 11th, 2006   #3 (permalink)
I am having the same problem with my curves being segmented. I cannot find the "curve steps" that Ray is talking about. Could you elaborate?
3dWalmart is offline
Old May 11th, 2006   #4 (permalink)
Never mind, just found it, thanks Ray!
Anyone else model in AutoCAD? Anyone use file linking? Reitveld AutoCAD/AutoCAD Architecture 44 September 27th, 2008 05:59 PM
File Linking utility as in Viz JamesTaylor 3ds Max 2 February 7th, 2005 11:37 AM
File Linking fernando-1 Autodesk VIZ 8 June 7th, 2004 07:00 PM
Acad solids triangulate in Max Noise 3ds Max 12 May 3rd, 2004 07:43 AM
Max6 and File Linking Vince Paske 3ds Max 6 August 19th, 2003 03:03 AM
