Thread: tiles patterns
Old March 9th, 2007   #1 (permalink)
al_farooq
Saudi Arabia  Send a message via Yahoo to al_farooq
Default tiles patterns
hi all,
i want to create tile patterns in studiomax how i can do? for example i have two kind tiles and one smaller frame between these tiles .becare full i want to use tiles original measurments how and where from i will set measurments of my tiles.explaination of room and tiles is given below
1-room length 5000mm=5m
2-room width4000mm=4m
3-white tile 400mm=40cm square
2-black tile 400mm=40cm square
3-strip length 400mm=40cm,width 150mm=15cm, that is gray colour
how i want to fix tiles
first of all two black tiles beside all walls
the gray strip after that in the strip rectangle i want to fix white colour tiles.
i will b thank full to all my friends which will help me about tile pattrens in stu
dio max i want to fix floor tiles in so many patters.so may i prepare my pattern first in autocad then importing in studio max or whole work will b done in studiomax pls answer quickly
with best regards
m.umer.farooq
al_farooq is offline   Reply With Quote
