Name: Harald Brutscher |
Hello,
my current project is an egg-shaped blobb. Now I would like to cut rectangular windows into this shape. I thought about the boolean command in 3DSMax. But most of the time, the model is being partially destroyed as you can see on the picture. Is there a better way of cutting exact rectuangular objects into free forms? Thank you, Harald |
Name: Joel Callahan |
Wow... I've never seen Max 7. I started with Max 8 and then got the ProBoolean add-on.
A few ways to increase the mesh density: * manually - by selecting the faces where you want to make your boolean, CONTROL + EDGE SELECT (this will select all of the edges from the faces that were selected), then connect the edges together. * tesselate - select the faces and then press tesselate * mesh smooth - select the faces (there's a pattern here... * turbo smooth - not sure if you've have that or not. Like mesh smooth, only a bit better Think of the mesh as a monitor. If you have to display a circle and there aren't enough pixels, it will be shaped funny. Not enough resolution to properly define the shape. Same with boolean and segmentation.
-SandmanNinja |
#7 (permalink) | |
Name: Claudio Branch |
Collapse your geometry to Editable Poly and select Polygon and the group of polys bounded by your merged shape are selected by default. Then you can use EP's Extrude command to finish the form. |
The approach I described above works very well, but will create some stray vertices along the boundary of the merged shape. These should be manually deleted using EP's Remove command.
Name: on kazan |
no need for booleans here.
either use pro-boolean (try installing it anyways it might work with max7 as well) or just do the whole thing using edit mesh or edit poly (negative extrude). ull get better results than either one of em. |
Name: teh jackie |
i am abit confuse of which step should go first, we have convert the object into editable-poly then go for pro-boolean or go for pro-boolean before convert the object into editable-poly??? which one should go first???
| Boolean Problems | claudia777 | General Discussions | 1 | February 7th, 2006 12:25 PM |
| Boolean modification troubles | WNB | General Discussions | 1 | August 3rd, 2005 08:19 AM |
| Boolean | Elliot | Autodesk VIZ | 5 | December 1st, 2004 11:04 PM |
| Boolean Problems | Sergio | 3ds Max | 12 | November 23rd, 2003 06:04 AM |
| boolean subtraction problem... | hockley91 | 3ds Max | 3 | July 10th, 2003 05:17 AM |
