Overwrite Error Causing Backburner Files??
I sent 16 jobs to backburner, all from the same animation, only to find that i'd left a old xref link in the file which couldn't be found and as such threw up errors in backburner.
So, once i corrected the error in the original scene file, i ended up having go through the whole process of resending the jobs to backburner...
i was wondering if its possible to simple overwrite the scene file that backburner is referencing, i know that backburner stores info regarding jobs in its install directory on both the Manager Machine and the Server Machines but which files would need replacing... the ones on the manager or the ones on servers, if its possible at all??
When time permits and if no one has the answer to this i'll see if i can test out and post the results.
Cheers
