Thread: nok li -WIP
Old May 4th, 2007   #1 (permalink)
nok li
Default nok li -WIP
At present, the scene are in the design, I take out the original corridor , the purpose I change it into a stepped plaza is to make the main buildings stand out. However, the current effect is not obvious, I will adjust it later. The model in foreground needs to be refined. I also will add some old buildings of local town, insert some glass blocks , so that a new meaning can be applied into the building. The final effect will not only keep old buildings, but also has some new modern elements, which will make strong contrast.
nok li is offline   Reply With Quote
