Name: Phil Fogerite |
looking to get a good workstation laptop that will run maya and Zbrush comfortably. I currently have a 1GB DDR2 dell xps and i hope to get something similar except with 2 gigs of ram.
I'm a little confused as to what exactly i have... stupid dells... i swear i'll never buy a dell again, i'm building my next computer! in my device manager i have listed: Dispaly adapters -Radeon x800GT -Radeon x800GT Secondary Processors -Intel Pentium 4 CPU 3.20GHz -Intel Pentium 4 CPU 3.20GHz does that mean i have two cards and 2 processors? for the laptop I was looking at the alienware area 51 m7700: Intel® Pentium® 4 640 Desktop Processor w/ HT Technology 3.2GHz 800MHz FSB 2MB 256MB NVidia® GeForce™ Go 6800 Ultra 2GB Dual Channel DDR2 SO-DIMM at 533MHz - 2 x 1024MB what do you guys think? suggestions on power, parts, and other options would be appreciated, budget is not too extravagant, but the laptop i'm looking at is $3,200 and thats affordable |
Name: andy wiggins |
I would imagine, if you have a Dell with a pentium it is an HT.. thats why you are getting two processors showing up in your device manager.
And you probably won't have two graphics cards either. You get two appear if you have dual view enabled, or a second connection on the card. Not a big laptop user, but processor speed and RAM.. they are your main allies. Alien ware do some cracking pc's.. from what I have seen. I'm sure the guys will come up with some more suggestions.. Andy
Andy Wiggins MAKING COFFEE. Making a cup of coffee is like making love to a beautiful woman. It's got to be hot. You've got to take your time. You've got to stir... gently and firmly. You've got to grind your beans until they squeak. And then you put in the milk. Swiss Tony. |
Name: James Taylor |
i'd have a search thro the forums here for similar threads, there have been quite a few recently asking the same type of question.
from what i remember the guys seem to think you'll be able to get better value than the alienware, and i'm sure will give you links to appropoiate laptop sellers. |
Name: Daron Pardine |
the alienware MJ-12® m7700i and MJ-12® m7700a are based from a Clevo notebook chassis ~ which you can get from powernotebooks.com, pctorque.com, sagernotebook.com. . . and maybe some others. Basically, if you go with something other than alienware you don't have to pay for thier marketing fluff. An X2 system, configured exactly the same, from A-ware and Sagernotebook.com come to a difference of around $300... the other vendors may provide even more savings.
that's including: WUXGA 1920x1200 display Athlon X2 4200 2 gb ram 80gb 7200 rpm hd Quadro FX1400 . . . which is what I'd get if I were you (assuming you don't have a desktop workstation)! Good luck Last edited by tecton3d; April 11th, 2006 at 05:49 AM. |
This thread is from last week, similar questions:
http://www.cgarchitect.com/vb/16067-athlon-mobile-64-x2-vs-64-fx.html In the end I bought an off-the-shelf Toshiba so I wouldn't be waiting 3 weeks to get the thing. I had to drive to a CompUSA and wait 1/2 hour while they swapped in the new RAM chips to get 2GB. About $3000 with the RAM. However, the Intel duocore chips are 32 bit I think. But not many of my day-to-day apps are 64bit, so it's working very well. The only issue I have is that since this thing is a consumer machine, it has lots of crap on it I really don't want, like 'AOL tryout' and it will take some time to get rid of all that. |
Name: Greg Hess |
Ernest,
The best thing to do is to completely wipe the drive and start over. (I'm not kidding). It takes less time to do that (after you download all the drivers first), then to sit there and try to remove all the thousands of megs of crap on there. If you'd like a utility to get rid of all the crap after you've "add/removed" all the programs, run... CCleaner (ie crap cleaner) http://www.filehippo.com/download_ccleaner/ It works quite well, and also has a built in registry cleaner, and startup menu editor. Btw in terms of laptops I can't recommend the duocore laptops enough. They are SLAUGHTERING the P4 based laptops. It's not even a contest. Avoid all full form laptops and just go with the power punch that the duocore's give you. A 2 ghz duo core laptop is basically like buying a dual 3.2-3.4 xeon that fits on your lap. |
#7 (permalink) | |
Thanks for the cleaner reference. When I have some downtime I will deal with it all, right now the laptop is too busy paying for itself. |
Name: Elliot Correa |
Hello
Last year I bought a 4K laptop from Dell. It is an Inspiron XPS. It was a horrible nightmare; they duplicated my order and charged me twice on the credit card. It took them 4 months to correct the problem. The machine is about the same speed as my 4 year old Toshiba. The Dell is bulky, heavy and the battery last about 20 minutes. The Power Supply is about 2 pounds and 2"x7"1.25". Several years ago they took me with 4 Sager we bought on which we spent like 12K and they were no good.... they lasted only about 1.5 years and fell apart. Now I feel Dell took me with this XPS. On my last trip to China (17 hours) the AC power cord on my seat was not working. I couldn't plug in the computer. The guy next to me had the same problem. However, he had a thin laptop (I don't know what brand name) with two extra batteries. He basically worked on his battery operated laptop all the way to China. He was using InDesign doing some kind of brochure. During the last 10 years I have always looked for powerful laptops. We must have purchased at least 15 units. None of them have been any good. The only of the shelve laptop we bought for an emergency was the Toshiba. That was the best one we ever bought. I still carry it when I don't feel like carrying the heavy Dell. Three months ago I left a 75 watt reading lamp about 1 foot away from the Dell Keyboard. The slight heat melted the keyboard. Unbelievable...... I have the extended warranty and Dell replaced the keyboard in three days. Lately I have been traveling with the Digital Camera, the laptop and the LCD projector.... A two pound power supply makes a big difference. A few weeks ago I got to Paris at 7 am and the hotel was not ready until 4 pm. It was Sunday and their suitcase closet was open and I was afraid of leaving too much expensive equipment inside an un-attended closet. It was a rainy day I spent 9 hours walking around Paris dragging two briefcases with wheels. The next laptop we get I hope it could have a nuclear power cell and no batteries or power supply. Greg's comments sound very logical..... Thanks Elliot
Elliot Last edited by Elliot; April 11th, 2006 at 09:02 AM. |
WOW thanks guys! i went to powernotebook.com like you suggested and found an amazing thing!!!
http://www.powernotebooks.com/product.php?itemId=1296 i started off my laptop search looking for the largest sceen size they had and was disappointed when i only found 17" displays... this thing has 19" and TWO of the most powerful graphics card you can get from alienware, and for the SAME price i was going to pay!!!! I have an option for the processor between these two listed below, could u guys tell me what level of pentiums they compare to? they are comaparable to 3.2+ speed P4's right? AMD Turion™ 64 Mobile MT-40 (2.2GHz 25W) w/1024KB L2 cache AMD Turion™ 64 Mobile ML-44 (2.4GHz 35W) w/1024KB L2 cache These are the graphics cards that come in it, I also wanted to make sure these are good cards for games, as i am a game developer and although workstation graphics cards like the quadro are powerful, theyre pretty useless if they have issues with playing my own games. This is a gamer card that will use the geforce drivers and not a workstation card right? DUAL NVIDIA® GeForce® Go 7800 GTX PCI-Express™ 16X Modules in SLI Mode w/256MB (512MB total) |
Name: Greg Hess |
Ernest,
Completely understand! When you finally do get some downtime, I'd still recommend a complete wipe and repartion...better yet, pickup a new harddrive to swap into the laptop. That will net you.. 1) Won't have to effect any of the files or programs on an already setup computer on one drive. 2) Gives you a brand new clean slate to quickly setup and install a new system 3) Gives you a spare drive thats completely setup to swap to in an emergency. When I say wipe and start over, I don't mean use the dell restore cd's...I mean take a XP disk (or your os of choice), boot to it, delete all partions, create new ones, format, and install. Make sure you make a cd with the current driver sets from support.dell.com prior to doing this. If you forget to, just swap in that other drive and go Once the system is cleanly setup and updated with the latest drives, windows updates, and programs you want/updates, ghost the system using a cloner of your choice. (I use norton ghost). Save the perfect clones for a year or two down the road when you want to refresh the system as if it had a fresh install. If you couldn't tell, I'm a firm believer in as many redundancies as possible. Backup drive, backup clones, backups on archival media, external hd's, and raid 1's keep mr murphy in the bahamas instead of your workspace. |
| Replacing my Workstation with a Laptop? | dtownsend | Hardware and Technical Discusions | 10 | April 5th, 2006 06:49 PM |
| 3ds/audio laptop | schmoron13 | Hardware and Technical Discusions | 10 | July 26th, 2005 05:31 PM |
| Why not a laptop? | Weider | Hardware and Technical Discusions | 11 | May 4th, 2005 03:30 PM |
| I need a Laptop, any advice?! | Aspiring Visualizer! | Hardware and Technical Discusions | 8 | March 3rd, 2005 10:25 AM |
| Ideal Workstation Configuration | Elliot | Hardware and Technical Discusions | 34 | September 22nd, 2004 08:27 PM |
