Old May 4th, 2007   #8 (permalink)
Horhe
Horhe's Avatar
Default Re: Problem with animation along path HELP
Its not a matter of the spline itself. The problem lies in the sampling of the path.
under the motion tab, select the samples spinner, and add more samples. I understand that you have a spline and you have created the motion path from the spline.
Before you create path add some more samples - by default its 10 i think, give it 32 and try it out.
The samples option does the same thing to the path as the interpolation does to the spline.
Horhe is online now   Reply With Quote
