Old May 7th, 2007   #2 (permalink)
CHE
CHE's Avatar
United_States  Send a message via MSN to CHE
Default Re: SketchUp to Modo 203
Hi Savnac,
I have imported Sketch Up models into Modo successfully in the past. What file format are you exporting to? Make sure that all your normals are facing the right direction in Sketch Up before exporting the model. Otherwise you are going to have to flip the polygons in Modo manually. I will be happy to look at your file and help you find the best way to do this. Send me a PM.
Ernesto
CHE is offline   Reply With Quote
