Old May 17th, 2007   #1 (permalink)
prodham
prodham's Avatar
Default material and radiosity problem
i am having a very unusual problem processing a radiosity solution on a particular project.
essentially the radiosity solution is crashing every time, even though the settings are good. as a test, i removed all the material maps (diffuse and some bump) and it works fine.
i can't understand this at all. the materials are not out of the ordinary and it is a student project where they are all using the same bitmap files. i have never had this problem before.....any suggestions ?
much appreciated
paul
prodham is offline   Reply With Quote
