Old May 17th, 2007   #4 (permalink)
vizwhiz
vizwhiz's Avatar
Default Re: 2007 VIZ file link to ADT?
Michelle
here is a link To The autodesk viz newgroups, search result for 'filelinking 2007'
http://discussion.autodesk.com/searc...2007&objID=c30
This is a more specific message you might want To read (and weep)
http://discussion.autodesk.com/threa...sageID=5256801
you may want To scroll down Thru The message and read The following:
Re: VIZ 2007 File Linking
Hi guys!
We also moved from 2006 to 2007 and had the same exact issue.
We found a solution though. It wont work as before with default settings. You have to create a new preset under File Link Manager/Presets and use it every time when linking a dwg file.
Check out the attached jpg image for the exact settings you should use in that newly created preset.
So..while importing dwg just pick that preset from dropdown list and it should work.. it sure does for us =)
Take care and let me know if it solved your problems.
Jyrgen A.
see attached jpg below
and further down below That (even)
micha,
i was having the exact same problem. i made the preset as described,
detached the file, then reattached it with the preset. no more problem!
previously i had just been trying to change the reload options, but that was getting me nowhere. i can't identify the exact root of the problem without more testing, so i'll suggest that you try to detach and then reattach the file.
best,
andrew
you may also want To read This, Too. but This is viz2k8 and max9+
http://usa.autodesk.com/adsk/servlet...linkID=9242898
i hope This helps
after working with Viz 2 Thru 4 i finally upgraded To max9 = same issues
it is amazing The fn FileLinkManager is such a POS, i rely on This a LOT!!
Randy
[Attachment: filelink_settings.jpg]
vizwhiz is offline   Reply With Quote
