Go Back   CGarchitect.com > 3D SOFTWARE > Scripts
Scripts Post and discuss architectural scripts or maxscripts here. This forum is for all software applications.
Old April 21st, 2006   #1 (permalink)
quizzy's Avatar
Default script: Random material ID
This script randomizes the material ID's in an editable poly by sub-object element. Just select an editable poly (editable meshes will be converted to editable poly), run the script, assign a Multi/sub material to the object.
check my website....
PS I made this script cause I collapsed a shingle roof into one object.
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old April 21st, 2006   #2 (permalink)
martincg's Avatar
Name: martin prochazka
Slovakia
Default Re: script: Random material ID
hi quizzy,
What is advantage opposite to "Material by Element" modifier?
btw thanks for sharing your other scripts.
martincg is offline
Old April 22nd, 2006   #3 (permalink)
quizzy's Avatar
uhm.. yes I didn't see that one.. BUT with my script you can begin numbering at 2 or 3 or anything..
Michiel Quist
http://www.3idee.nl
quizzy is offline
script: Random Replacer quizzy Scripts 3 July 4th, 2006 10:53 AM
Script WIP : Material Lister re:FORM 3ds Max 0 March 1st, 2006 04:52 AM
Random glass tile material Tim Nelson General Discussions 20 January 26th, 2005 05:39 PM
script: Random materials quizzy Scripts 0 September 25th, 2002 12:59 AM
Material Script nisus Scripts 5 July 8th, 2002 11:49 PM
