Old April 21st, 2006   #1 (permalink)
Pakistan
Unhappy 360 Degree camera in vray
hey i want some help. i m using vray with irrmap for primary bounce and lightcache for secondar bounce. i have 60 frames animation.
instead of calculation for irrmap and lightcache, i wana save them first and then reuse them.
my question is:
1. can i save my irrmap and lightcache at frame 1 with 360 degrees vray camera and then use them to get aniamtion rendered?
does the vray gives good results. actually i have a slow system
3.0 GHz, 1GB RAm
Matrox Parhelia 128 MB APVe
thats why i want the answer before putting it on rendering.
thanks for your replies
aligrafix is offline
Old April 24th, 2006   #2 (permalink)
Craig Ramsay's Avatar
Default Re: 360 Degree camera in vray
It really depends on what your animation consists of. Can you tell us more about the animation... is there animated objects, changing light etc?
Craig Ramsay is offline
Old April 25th, 2006   #3 (permalink)
Pakistan
Sure. There is no animation of lights and materials.i am only animating camera and the lenth of animation is 100 frames, i just want to render 1 frame with (360 degree vray) camera and save the IRmap and lightcache. If i use the saved IRmap and Light cache, will it work for me for whole animation. Is it a good shortcut?
Old April 25th, 2006   #4 (permalink)
Pakistan
Well i forgot one thing. i have animated particles in max for smoke effect. if i animate objects! then will it work with animated objects and cameras while there is no animated lights?
Orthographic, Vray, and Camera Correction charbroil General Discussions 2 August 26th, 2005 10:25 AM
Vray and Brizal Rio plug in Chris Potts Other 3rd Party Renderers 7 September 16th, 2004 01:01 AM
Ten vray questions steve VRay Render 9 September 15th, 2004 04:42 AM
Vray and Camera Correction Modifier. It's a No-No. crazy homeless guy VRay Render 2 June 2nd, 2004 10:38 AM
VRay against Vray and ... Sergio VRay Render 15 May 30th, 2003 08:09 AM
