Old April 25th, 2006   #1 (permalink)
Philippines  Send a message via Yahoo to odi120522
Default Is Saving Irradiance Map Helps Lower Rendering Time?
Hi...is Saving The Irradiance Map Can Improved Rendering Time? Bec. I Did A Test Render With Output Size Of 2048 X 1536 With Lots Of reflective Objects Like Glass And Alluminum Metals..it Took The Final Rendering More Than 10 Hrs To Render...i Dont Know If Thats Normal But I Think Its Not...hope You Can Help Me On This....tnx...if You Can Give Me Some Tips On How To Make The Rendering Time More Faster I Would Greatly Appreciate It....tnx In Advance...
odi120522 is offline
Old April 25th, 2006   #2 (permalink)
ApeiNe's Avatar
Default Re: Is Saving Irradiance Map Helps Lower Rendering Time?
that would be good to know all the rendering parameters, coz all can be a fact of excessive time.
Antialiasing
1st bounce & params
indirect bounces & params
rQMC sampler
ApeiNe is offline
Old April 25th, 2006   #3 (permalink)
hockley91's Avatar
If you are using Vray then yes! The irradiance map is essential to save. If you ever need to re-render at a different resolution, or if you need to fis/replace something in the image, then saving the irradiance map can save so much time.
Depending on the complexity of the scene, the lighting calculation can take a significant amount of time, also depending on the quality of the lighting calculation ie, very low, low, medium, etc.
Having to re render and then do a light calc again is time wasted.
You can either save the Irradiance Map automatically or manually. If I do it manually, I have to save it right away. If I start doing some other things after it's calculated I lose the lighting information for some reason....
Hope this helps!
Adam
hockley91 is offline
FIRST TIME NIGHT RENDERING - with file DUH Diver Finished Work 2 December 13th, 2004 10:22 PM
First Time Night Rendering Diver Finished Work 1 December 13th, 2004 10:10 PM
Massive rendering time....am I doing something wrong Apropos General Discussions 15 October 1st, 2004 08:26 AM
Lower your Rendering time by 10 Renderman Autodesk VIZ 3 January 4th, 2003 08:27 AM
