Re: Help! cant find render dialog window....
if it is set up like 3dsmax, you can open the equivalent to the 3dsmax.ini file, and then locate the "RenderVFBPosition" line. it will look something like this.
[RenderVFBPosition]
Position=100 140
the position represents the pixel position of the top right hand corner of the dialog box. make sure it fits within the resolution of you screen. if not, change it so that it does. now save the file, and launch max. it should show up then.
i also read on this board one time that you can simply delete the 3dsmax.ini file, and it will be recreated the next time you launch max, and all settings will be within you monitor, however, i have not tested this method. ...and i guess there is a chance that it will erase some other of you settings.
again, this is for max, but i would guess that viz is set u in a similar fashion.
