Old April 29th, 2006   #1 (permalink)
akzit's Avatar
Name: Jorge Tiscareño
Default 2007 with feautres like SU...
Was reading in another post that Acad 2007 has incorporated some great new 3d features liie push/pull just like sketchup???
Anyone using 2007? What other great new things are there for modeling in 2007?
"That you are here--that life exists, and identity;
That the powerful play goes on, and you will contribute a verse."
Walt Whitman
akzit is offline
Old May 13th, 2006   #2 (permalink)
Default Re: 2007 with feautres like SU...
I havent had much time to explore the new features of 07 but there is a loft tool which is long overdue to ACAD. You can also draw just draw on a face by just clicking on it instead of orienting your ucs. Another Cool feature is that you can just use shift instead of using the 3d orbit tool which is kind of cool. You can also work on your model in Perspective mode as well. Shade mode is a lot better so now you can work on your model in shade mode without any problems. Finally It now comes with Mental Ray though it isn't nearly as good as it is in Maya, Max, or XSI. There may be a ton of new features that I left out but Those are the main ones I noticed right off.
Karlfucious is online now
Old June 6th, 2006   #3 (permalink)
Cesar R's Avatar
.. you can also import DWF files and trace over them with snaps =)
you can print to PDF's
Visual Styles - which let you go from a shades view to a sketch up drawing style,
enhanced Camera animation and keyboard controled walkthrough like in max FPOV
If you go to your window pulldown you can enable the "dashborad" wich is the 3D modeling aspect incorporated in this release.
Xeon 5130 : Revit + 3DSMax
Fa5 - Honda Civic Si
Cesar R is offline
autocad 2007 and my 64 bit system 3dsmaxed AutoCAD/AutoCAD Architecture 2 April 29th, 2006 10:53 PM
autocad 2007 ... 3dsout missing kippu AutoCAD/AutoCAD Architecture 7 April 13th, 2006 04:12 PM
Max 8 and AutoCad 2007 Vince Paske 3ds Max 5 April 8th, 2006 03:28 PM
Viz 2007? tcorbett Autodesk VIZ 20 April 5th, 2006 02:40 AM
Upgrading Viz 2007 VS Max 8 fernando-1 Autodesk VIZ 1 March 31st, 2006 04:56 PM
