Old May 2nd, 2006   #1 (permalink)
Default Vray and exposure control preview
I am using Max7 and vray free. ( I know I should upgrade, but its not my call on that one.) Anyway I am trying to use the exposure preview, and when I do all I see is a rendered black box. I get this no matter what type of exposure I try. Am using a single direct light with vray shadows, with GI checked.
HELP
frank1331 is offline
Old May 2nd, 2006   #2 (permalink)
ApeiNe's Avatar
Default Re: Vray and exposure control preview
Just forget the max exposure control, never use it whith Vray.
Try to get a look at :
Rendering >> Render
Renderer
Color Mapping
U got the choice between some exposure right here.
If it's only for a preview, make a 300*200 render ^_^
ApeiNe is offline
Old May 2nd, 2006   #3 (permalink)
AJLynn's Avatar
I don't think Free does that. But yeah, don't use exposure control, if you're getting black exposure control isn't the problem. Are you using Architectural materials? Those don't work.
AJLynn is offline
Old May 3rd, 2006   #4 (permalink)
Thanks fir the help. I am using standard materials not architectural, so thats not it. It renders fine whe I render it through vray, I was just wondering why it looks so bad in the exposure preview.
This all started when I started to play with an ms script I have that renders each object out individually as a matte/alpha mask. Through the scanline render engine the objects look fine, but when I tried it using vray everything was very dark. So that is when I noticed the enviroment preview render.
Does anyone know a way to render out individual objects with a script using vray free?
Old May 3rd, 2006   #5 (permalink)
ApeiNe's Avatar
TO make a Matte/shadow on Vray, just right click on your object >> Vray properties, then check matte surface and affect -1 to the alpha contribution
ApeiNe is offline
Old May 3rd, 2006   #6 (permalink)
FlytE's Avatar
Name: Andy Pennington
Scotland
Its funny you say never use exposure control.... I always thought the same thing with vray, until a colleague of mine did some vray renders using logarithmic exposure control and they looked lovely. Saying that, they were only white card model renders with a little bit of materiality in them, but they still looked really nice.
FlytE is offline
Old October 29th, 2007   #7 (permalink)
On the free Vray do you have Light Cache (it's in Indirect Illumination)? If so, this is a pretty useful tool for checking lights and stuff.
When you click on Light Cache have the multiplier at 0.8 and the subdivisions down to 500 rather than the default 1000, this also speeds the render up a bit. It gives you an alsmost instant preview, so you can see what your scenes lighting looks like (pretty much).
Also for speeding up mess around with your Global Switches. Drag a base material as an instance (simple off-white) into the tab next to Override Mtl. and turn on Override Mtl. This renders everything in this material, great for white-card models. For normal renders turn off glossy effects, this speeds things up too.
I think I've waffled on a fair amount now! A little off the subject, but hopefully helpful anyway?!
BIG Col is offline
can't use radiosity after installing vray? eduardocalvo VRay Render 2 April 17th, 2006 11:16 PM
Problems with settings for external Vray scene alfienoakes VRay Render 6 October 6th, 2005 07:58 AM
vray free where do i start? Timothy Saunders VRay Render 13 August 12th, 2005 04:03 PM
VRay Free turning off the ambient light? AJLynn VRay Render 3 August 4th, 2005 08:40 AM
Vray X Daylight X Enviroment Tchebli 3ds Max 1 March 4th, 2005 08:02 PM
