Old June 6th, 2007   #2 (permalink)
chiquito
chiquito's Avatar
Argentina
Default Re: Quick question on UVW unwrwapping
try with uwrap uvw map,
another solution would be to just get a screen grab and use that as a photoshop file, if you with this, use a reference plane, so you can refer to for mapping coordinates latter on, or with the size and aspect of image in photoshop, you do not want to be guessing up little numbers and testing results with uvw map, its a worthless effort. only thing then is that you will loose all the "elevation" texture capabilities, you will only be able to match a plan view.
If its no so complicated, I will go for the unwrap, you can alter and play along with detail directlly from photoshop.
chiquito is offline   Reply With Quote
