3ds Max Autodesk 3ds Max
Old May 5th, 2006   #1 (permalink)
Name: karl kirchhofer
Default Camera path question
I am trying to get a camera to circle an object. If I keyframe the the camera at four different spots around the object the camera moves in a pretty straight line between these points-
Is there a way that I can modify the path or control how sharp of a turn the camera takes at each of these keyframed locations to get a smootehr path?
thx.
karl
kwerch is offline
Old May 5th, 2006   #2 (permalink)
Default Re: Camera path question
are you only rotating around the object?
Mike
mtutaj is offline
Old May 5th, 2006   #3 (permalink)
Yes. That's what I am trying to do-
kwerch is offline
Old May 5th, 2006   #4 (permalink)
in max, draw a circle around your object. Then I typically use a target camera. place that in your scene. highlight the camera. then click on the motion tab, and expand the assign controller. Highlight the position-positionxyz, the click on the ? box just above and select path constraint.
now go down to the path parameters and click on add path and select the circle. Now your camera should revolve around the object for the length of the timeline.
Mike
mtutaj is offline
Old May 5th, 2006   #5 (permalink)
Thanks Mike, that works -
I see that when I turn this circle into an editable slpine that it appears to change the path as well- But when the animation is played, the spline reverts back to the circle.
I guess if I knew I wanted to modify the path from the get go, I could change the circle to the editable spline before assigning it as a p[ath-
I'll play with it later-
thx.
karl
kwerch is offline
Old May 5th, 2006   #6 (permalink)
surprise, it doesn't quie work as I expected. THe circle changed int0o spline and modified a bit then assigned as the path reverts back to the circle when the animation starts-
Hmmm-I wonder how to set up some sort of editable path for the camera.
thx
kwerch is offline
adjusting real camera angle with max camera edward80 3ds Max 1 March 26th, 2006 11:18 AM
Camera matching question MazenSamir 3ds Max 4 February 20th, 2006 07:40 AM
Camera Match question frank1331 3ds Max 8 July 28th, 2005 06:40 PM
Camera Animation Probs! claudia777 3ds Max 3 May 23rd, 2005 02:15 PM
camera shaking problem stinkyz 3ds Max 7 April 12th, 2004 01:44 PM
