3ds Max Autodesk 3ds Max
Old May 11th, 2006   #1 (permalink)
Default New Mental Ray grass displacement tutorial
Since the existing grass shader on my site is starting to show it's age, I thought I would share one of my more current methods of displaced grass. Here's the link: http://jeffpatton.net/MR_Grass_displacement.htm
pixelperfectg is offline
Old May 11th, 2006   #2 (permalink)
TheAllusionist's Avatar
Default Re: New Mental Ray grass displacement tutorial
Thanks for sharing, a pretty sweet effect for a common need in Arch Viz
The Opinions Expressed Here Do Not Necessarily Reflect Those of a Rational Mind.
3DAllusions | 3DAllusions Studio | MrMaterials
TheAllusionist is offline
Old May 12th, 2006   #3 (permalink)
nisus's Avatar
Name: Evert Vandenberghe
Belgium
Tnx Jeff,
Do you know about a limit of how large the surface can be with your grass?
Have you experimented with depth falloff to save rendering time on not having to displace at larger distances?
rgds,
nisus
nisus is offline
Old May 12th, 2006   #4 (permalink)
nisus's Avatar
Belgium
Hi Jeff,
I've checked your new tutorial. It looks great and simple.
I have a question about your render settings though.
Why do you set FG max and min radius to the same value? I've read that these should be 10x apart, basicly 1/10th and 1/100th of the scene diameters.
What are your findings upon these values/rules of thumbs?
rgds,
nisus
nisus is offline
Old May 12th, 2006   #5 (permalink)
Yes, at times I use various materials to control where displacement occurs on large objects. No sense in having a displacement calculation when it can't be seen (behind objects), or won't be noticable simply due to the camera distance.
As I briefly mention in the tutorial, the settings I used are just for simple/fast preview renders. naturally, the FG won't be super accurate, but for testing, it works well. And since I really only needed a touch of skylight for this scene I just left the FG at my test values.
mental ray exterior rendering tutorial? Sirkus Other 3rd Party Renderers 3 January 31st, 2008 01:05 PM
site - vray grass / displacement map tutorial Gleggers General Discussions 6 July 13th, 2007 08:10 AM
Setting up Mental Ray to render with 8 CPUs (video tutorial) Paulo Kiefe 3ds Max 2 June 20th, 2006 02:26 AM
Mental Ray displacement! aflack 3ds Max 1 June 25th, 2004 05:09 PM
