Old May 11th, 2006   #1 (permalink)
Question Lighting Simulation research
Im Doing An Aplication Research on Lighting Simulation
and I need a tool for:
1-Developing realistic rendering
2-Lighting Studies (Illumination Distribution) Charts OR images (lab results) .
I am using Vray for my Professional REnderings And Presentations and i think that it Irrelevant in this research for the lighting lab Results. i ve seen some previous research most of them where using lightscape. i never used it before.so i need some guidance.
-my time is tight do u recommend that i do these test renders my self or using a pro is more convenient as inever used light scape be4 ?
tahoon is offline
Old May 12th, 2006   #2 (permalink)
oluv's Avatar
Default Re: Lighting Simulation research
lightscape is "more or LESS" integrated into max8 radiosity. you have nearly the same lighting analysis tools as in lightscape.
simply setup your scene with architectrual materials and let a radiosity calculation start. the most important fact are phyically based materials, it will work best when you use architectrual materials.
oluv is offline
Old May 12th, 2006   #3 (permalink)
Maxer's Avatar
I'd recommend getting a pro to do the work for you unless you are very good at learning a new app relatively fast. This is especially true if you want good reliable data, radiosity can be tricky.
“There is no spoon”
Maxer is offline
What does "Shooting Lights" in Advanced Lighting do? garyhasler Autodesk VIZ 4 April 24th, 2006 11:15 AM
Interior Lighting taemoor General Discussions 2 February 28th, 2006 12:16 AM
lighting information madsekci 3ds Max 2 September 28th, 2005 11:09 AM
interior lighting haneet khanna 3ds Max 1 April 30th, 2005 04:08 AM
