Old May 16th, 2006   #1 (permalink)
Default Glass Problem
Im having problems with glass in LS couse I get strange black splotches when RayTracing.
My model doesnt have any too small polys so nothing dissapears when I render model like ideal diffuse material.
Do I have to model "air polys" for the glass (offset the surface of the glass to the inside and make reffraction index 1.0,also reverse the direction of normals), wich I did but problem ocures again.
Heres a screenshot of my model (revolved curves).
Whats the trick?
Beeeee!
del82 is offline
Old May 16th, 2006   #2 (permalink)
Ernest Burden's Avatar
Name: Ernest Burden III
Default Re: Glass Problem
You do not need the inner surface, just use the outter one (red in your example). Otherwise, make sure you have a high enough ray bounce--you're using up 8 bounces just getting through all those glass surfaces. Is the background black? If it's reflecting, perhaps put in some lighter 'cards' to reflect.
Ernest Burden III
AcmeDigital
architectural rendering
Ernest Burden is offline
Old May 16th, 2006   #3 (permalink)
Ray bounce is up at 10. I dint change it.
What do you mean by black background?
The model is interior, illuminated by the sunlight. All wall surfaces that are sourounding the glass are white.
Theres also the "window" surface but its also white colour.
Theres nothing black to reflect.
Beeeee!
del82 is offline
Old May 16th, 2006   #4 (permalink)
o.k. I also tried with raybouncing up to 35 but nothing!
Beeeee!
del82 is offline
Glass problem with Vray glass alvstel 3ds Max 10 November 21st, 2007 11:44 PM
Vray Glass Problem Hallock VRay Render 8 June 14th, 2006 08:37 AM
mr problem with glass mr material with dielectric msamer 3ds Max 9 April 6th, 2006 11:34 AM
window glass problem roland Work in Progress (WIP) 5 January 2nd, 2006 04:00 AM
Glass Problem bully712 Autodesk VIZ 2 April 4th, 2005 07:58 AM
