3ds Max Autodesk 3ds Max
Old May 18th, 2006   #1 (permalink)
Brian Cassil's Avatar
Default do you use photometric lights with GI?
I've gone back and forth on this maybe 6 or 7 times, and I'm curious to know what others do. I like the photometric lights because I get better reflections with them but they also seem to wash out the scene more. It may be that I am doing something wrong though. I like the standard lights because for me they are more flexible, without having the dynamic range of photometrics my reflections never look quite right. Again, I could be doing something wrong.
Personally I use Final Render, but I would like to know from users of any renderer what kind of lights they use.
Brian Cassil is offline
Old May 18th, 2006   #2 (permalink)
Rick Eloy's Avatar
Default Re: do you use photometric lights with GI?
Well, I normally use photometric lights and never had a problem with them. They work well with VRay (although a bit slow) and very well with radiosity. Not only reflections look good, also the whole lighting gets smoother and way more natural.
I guess the trick is you have to treat them as you would treat real lights. I normally work in Lux instead of Candelas (all technical specifications I get are in Lux, so...) and they work sweet.
Rick Eloy
Rick Eloy is offline
Old May 19th, 2006   #3 (permalink)
hey brian, we just started using photometric lights with finalrender where i work and really the only problems we have encountered is if you have the standard raytrace shadows set instead of fR raytrace shadows - then we have experienced crashes. other then that i love the photometric lights, and you can still cheat with them a little if you need to, by adjusting the multiplier, changing candelas or even using the exposure control.
randy
rmoore97 is offline
Old May 19th, 2006   #4 (permalink)
Sawyer's Avatar
I have been using Chris Nichols' tip that he showed in the interiors DVD. I Use a photometric file creator. Their are way too many photometric files out their and most of the time I don't get specs on lights so I can fudge them this way. I would spend all day testing files till I found the ones I liked.
That all in vray.
And you may ask yourself
What is that beautiful house?
Sawyer is offline
Old May 19th, 2006   #5 (permalink)
Rick Eloy's Avatar
[quote=Sawyer]I have been using Chris Nichols' tip that he showed in the interiors DVD. I Use a photometric file creator. [quote]
That sounds interesting. How does it work? I mean, I've seen people writing their own IES file, but I simply don't have what it takes to do it.
Rick Eloy
Old May 19th, 2006   #6 (permalink)
Sawyer's Avatar
I have a program its called ies_gen3 its a free thing I found online. I am sure there are better ones. Chris used one in his dvd that looked better but I have forgotten it's name. Anyway you can just draw a profile of light, save it and use that as your web distribution file.
Here are some screen captures of the program, wire of the light and result.
Sawyer is offline
Old May 19th, 2006   #7 (permalink)
Rick Eloy's Avatar
Sweet! I'm gonna check it out. Thanks!
Rick Eloy
photometric lights kamikaze 3ds Max 8 July 17th, 2005 10:21 PM
MR: photometric lights with MR nisus 3ds Max 1 August 30th, 2004 11:05 AM
Photometric lights - I'm a dummy... Ken Walton 3ds Max 2 February 20th, 2004 01:10 AM
MR and photometric lights? 723D 3ds Max 2 January 24th, 2004 04:02 PM
photometric lights killing my rendering schmoron13 3ds Max 3 November 14th, 2003 01:52 AM
