Old July 5th, 2007   #2 (permalink)
wda
wda's Avatar
Name: William Alexander
Default Re: My jump into Modo via MicroStation XM (WIP)
To copy...you need to open the new file. It will show along with the files already there.
Try to dragging and droping a mesh from one file to another in the item list view. Make suer the import dialog box has everything checked. You materials from the imported mesh appear in the group called imported shader of the shadertree view. Usally very few problems with the materials until you copy only polys and paste into a mesh. Then you need to restructure the group and base shader in the render>shader tree.
WDA
wda is offline   Reply With Quote
