Re: My jump into Modo via MicroStation XM (WIP)
Modo does not support 3ds files. It has a DXF importer/exporter but it is very slow and it doesn't always work well. You can also try exporting to OBJ but I have had better results with LWO files. AccuTrans will translate your layering and in some cases cameras and UVs. I do have not experience any "merging" of layers after closing and opening th LXO before. Do you loose all your mesh items when that happens?
