Re: Using AutoCAD files in VIZ?
i don't see why there would be any issues with ADT data (or architectural autocad nowadays) in VIZ.
as long as the objects import or link correctly, material mapping should be the same.
i've never used the door/window systems in VIZ (since i model in autocad mostly). maybe somebody else can tell you whether VIZ is better for that.
or try it out yourself and see which you prefer, or are more comfortable with.
