Old July 12th, 2007   #4 (permalink)
claudioarchi
Default Re: semi transparent glass
Originally Posted by chiquito View Post
yes, if you are using Vray, try varying the refraction glossines should give you that effect, the further away from 1 to 0 (ej 0.6) the more blur you will have on your translucency. Good luck
i'm sorry i don't have acces to vray this is a modo rendering. It is easy to do it in LW with nodes but i just want to test modo capacities. Thanks any way
claudioarchi is offline   Reply With Quote
