Old July 16th, 2007   #2 (permalink)
chiquito
chiquito's Avatar
Argentina
Default Re: Modelling advise needed - loft??
It could be a Loft, the shape can be scaled along certain axis, and moved exentrictlly fom the path, its posible, also, you could use a two shape loft, so you could have lots of variatiation with that tool. If I where you I would play a little with the deformtions on the loft modiefiers palette, try adjusting curves, smothing them, adding vertexes, etc.
Good luck
chiquito is offline   Reply With Quote
