Old May 30th, 2006   #1 (permalink)
alikashan's Avatar
Pakistan  Send a message via MSN to alikashan Send a message via Yahoo to alikashan Send a message via Skype™ to alikashan
Thumbs up ucs world is wrong
guys normally in every drawing ucs world is straight. but i have some dwgs fromt the consultant that when i try to change ucs to world coordinates it become angular instead of default result for
ucs=world
and if i try plan=world command my plan rotates to some angle
what is the settings changed in this dwg any one can tell me
thnx
Ali Kashan
Stranger than LIfe......... but Still Learning
alikashan is offline
Old May 30th, 2006   #2 (permalink)
Bulgaria
Default Re: ucs world is wrong
Go to menu View - 3D views - Current UCS or World UCS
i_petar is offline
Old May 30th, 2006   #3 (permalink)
how do you mean angular?? do you mean its doesn't line through with the horizontal and vertical lines of the drawing? will it not just be the case that the drawing has been done with north pointing directly vertical??
JamesTaylor is offline
Old May 30th, 2006   #4 (permalink)
alikashan's Avatar
Thumbs up Re: ucs world is wrong
Ok let me explain
ist image is the image with command line ucs/world
second image is with command line plan/world
may b it clarify my qusetion
Ali Kashan
Old May 30th, 2006   #5 (permalink)
I think if you determine the angle to that world UCS and start a new drawing and insert it as a block it will correct it for you although you may have to rotate it when in the new drawing.
BobM
BobM is offline
Old May 30th, 2006   #6 (permalink)
if a drawing demands that you set your ortho lines to follow a certain angle and you dont want to rotate the drawing then you can use the command.
snapang then simply click the basepoint of an angled line and click somewhere along its lenght -
this will set your UCS to the angle of the desired line.
This way you can set your ortho off that lines angle not the standard straight up and down setting....
soulctrla is offline
What is wrong with MentalRay?? archkre 3ds Max 18 January 23rd, 2005 10:34 PM
3rd World Memorandum Archmage General Discussions 24 May 18th, 2004 02:27 PM
Learning to see the world. . . garethace General Discussions 4 September 4th, 2003 12:35 AM
3dorbit and UCS problem salty_dogs AutoCAD/AutoCAD Architecture 2 March 27th, 2003 02:41 PM
UCS Problems in ACAD 2002 Jeff Mottle AutoCAD/AutoCAD Architecture 2 December 5th, 2002 01:06 PM
