GETTING 2D CAD DATA INTO MODO (Via MicroStation XM + Deep Exploration 5.0)
USEFUL LINKS:
http://forums.luxology.com/discussio....aspx?id=13431
http://forums.luxology.com/discussio....aspx?id=13233
DWG to DXF Workflow Option
In Export Settings: Entity Mapping > Convert All to 'Polylines' when possible
Condense levels as much as possible until Modo 301
Drop All Elements to linework
Found some translations when put into Modo via X's DXF get flipped, such as with arcs
Anything not dropped does not translate
Open In AccuTrans
Save As a large LWO file
Fast and Accurate
DWG to LWO Workflow Option
CAD Version of Deep Exploration used for DWG > LWO
DWG to LWO Export
Sometimes loses line color data in translation
Computer Inensive
DWG to DXF to LWO Workflow Option
CAD Version of Deep Exploration Used for DXF > LWO
Same as above, with line color maintained
Computer Intensive
GETTING 3D CAD DATA INTO MODO (Via MicroStation XM + Deep Exploration 5.0)
MicroStation XM > U3D > LWO
Level Structure Does Not Remain after Save of LXO File
Must go through each level (mesh), find greyed out levels (meshes), delete these (do not delete child objects)
Then Move geometry that collapsed to ouside of tree to the inside of the level (mesh) desired
Right-Click > Convert to 'Group Locator'
Now the LXO file will reopen with selectable levels (meshes)
